Thread: Renault megane scenic navi stoped working after inserted carminat cd !!!
    qsenc is offline Lance Corporal
    when i insert the cd in my renault megane scenic from 2000 the unit stoped working . now it shows only hour, and i can't start it. even radio stoped working. can some one help me in this matter?
    hell is offline Lieutenant General
    1,409
    Re: Renault megane scenic navi stoped working after inserted carminat cd !!!
    first what kind of cd?
    second what nav system , nav4 or nav5?
    third neither in above systems has the radio really close relationship with the nav unit only they share a common screen
    is a carminat informee. i have rezolved de problem by removing the battery . Now unit starts but can't read any cd. i hve write the cd with alcohool at low speed. Could be the lens of cd?
    1,409
    look there are different carminat generations:
    the carminat navigation inofrmee 1 can be NAV4 or NAV5 or NAV6 , as your car is from year 2000 it is either nav4 or nav5.
    are you sure that you have written the correct disc ? just because you asked in a carminat navigation informee 2 topic, which disc is definitely not for your system.
    on the other hand a wrong disc should have been simply rejected normally without any consequence
    Thank you for info !!
