Thread: How to Root (and Unroot) the Sony Xperia M Dual
    Jan 2014
    Rooting is the process of gaining administrative rights on your Android device. Once we root our Android device, we can then make changes to it to customize it well beyond what it normally can do.
    Once you have root access on your Sony Xperia M Dual, you’ll be able to:
    • Remove apps that were preinstalled by your carrier/manufacturer from your device.
    • Free up storage space (because of the above benefit).
    • Increase battery life (apps that might have been running constantly can be removed).
    • Increase performance (after removing apps that are always running, the device will be less bogged down and run smoother).
    • Update to a new version of Android (by flashing a custom recovery/ROM, see the end of this procedure for more info on that).
    • Tons of other customizations when you use your new found administrative rights to flash a custom ROM (again, see the end of this procedure for more info on that).
    • Interested? Here’s how to root your Xperia M Dual:
    I. Before You Begin
    1. Back up everything you feel is important.
    2. Charge your device to 75% or more before you begin.
    II. Necessary Downloads [or the latest version available]
    III. Rooting the Sony Xperia M Dual
    1. Extract to a folder on your desktop.
    2. Enable USB Debugging on your device. To do this, go to Settings > Developer options and tick the USB Debugging checkbox. If you don’t find Developer options listed in Settings, go to Settings > About phone and keep tapping on the build number until you see the message ‘you are now a developer.’ You should now find Developer options listed under Settings.
    3. Connect your device to your PC. If your PC installs drivers at this stage, let it do so and then continue with the procedure.
    4. From the extracted folder, double-click on Impactor.exe.
    5. Choose # drop SuperSU su to /system/xbin/su from the drop-down menu.
    6. Click on Start in the Cydia Compactor app.
    7. Once Cydia Compactor has finished its job, your device should be partially rooted. To complete the rooting process, go to the Play Store and install the SuperSU app and Busybox.
    Your Xperia M Dual is now completely rooted!
    IV. Unrooting the Xperia M Dual
    1. Open up the SuperSU app from your app drawer.
    2. Tap on the Settings tab.
    3. Under the Cleanup section, tap on Full unroot.
    4. Reboot your device.
  2. The Following User Says Thank You to veronicajackson91 For This Useful Post:
    filipaki is offline Private
    Mar 2015
    Re: How to Root (and Unroot) the Sony Xperia M Dual
    Thank you for the info ;
