Thread: Simple how to section?
    May 2011
    Hi Like a lot here I am new to the whole Sat Nav experiance. Good or bad I have the Predator Double Din unit from Chinavasion.
    I would like to install either Garmin or Tom Tom to the unit. I have spent a bit of time searching but I dont really understand what I have to do to get it all together.
    Is there a section with a dumbed down guide? eg what needs to be downloaded how to install etc.
    Also can I purchase a software package from Garmin or Tom Tom that will work without modification?
    Im sure I will come up with many more questions, but thanks for now
    T
    Andehh is offline Lance Corporal
    Apr 2011
    Re: Simple how to section?
    I am in the same boat mate! Do i need to download 5 x 400mb (ish) files, and extract them all onto the SD card of my china double din sat nav? The file hosting sites do not make it an easy process and I was hoping to find some details on whether I am going about it the right way!
    Charliefarlie is offline Private
    Jul 2011
    Same boat here Too ....
    Jul 2011
    I don't think TOMTOM software can be used without modification. I have TOMTOM 1 and the advert for the chinese Sat Nav, which I wanted for my caravan towing, said it could use TomTom Maps, but I tried to use the SD card from TOMTOM but it didn't work. So my guess is software compatible with windows CE 5.0 ( the OS of the chinese unit) is needed to fire up the system then it will use the maps. Just my guess, after trolloing through Tinternet. However I have emailed the seller and asked the Q. If I get a usefull reply I will post it here.
    RGDS
    Allan2426
    lawiswar is offline Private
    Jan 2012
    I gather that the answer to this thread was simply no?
    Apr 2012
    I also have a chinese generic from ebay and have been running it with the pre installed 2010 maps from the unit and need idiot proof instructions on how to download and use up to date igo maps from micro sd card?
