Thread: How to enable TTS in Sygic 11.02 on Android.
    Hans23 is offline Private
    I have an Android phone with Sygic 11.02 installed on it. Its a trial version. The software works well except for TTS. In the settings, I am not able to choose TTS as the options are grayed out. Please help.
    bigsatan is offline Private
    Re: How to enable TTS in Sygic 11.02 on Android.
    Version 11.20 is TTS compliant (only english voice is available anyway)
    Nov 2011
    I am running 11.2.1 and the txt to speech option is grayed out, anyone know how to enable ?
    Nov 2011
    Rhoon, The Netherlands
    If you select a TTS voice in the Region settings, TTS will be enabled.
    Nov 2011
    Kool , that fixed it. I was thinking that the normal voices could read street names, but it is only the TTS voices that can.
    applle is offline Sergeant
    Feb 2012
    25
