Results 1 to 1 of 1
Thread: Need some info on MAPMYINDIA, SYGIC Software and MLM / Licenses
    13thChip is offline Private
    Oct 2011
    I have been using MapMyIndia for about an year now but that was on an iPhone and iPad(2) that were Jailbroken. I had no issues with licenses or what not. But 2 days back I bought two dedicated GPS units ( Hugel (600) Sirf III running on Windows CE 5.0 and Innovatek Box SirF iV running on WM 6.0) and I did manage to get MapMyIndia loaded on it with maps after following the discussions here. However, there are somethings that I am not quite sure on.
    1) The Difference between Sygic, MapMyIndia and Aura. What is the latest and best cracked available version?
    2) Compatibility Matrix for Maps with these softwares. Can I just replace the old maps folder with a new one? I did but didnt work.
    3) What is MLM and what is its purpose? If its not there & since I use the mlm file to generate the activation code, , how do I generate the .mlm?
    4) Is there 3D Maps for Bangalore, India routes?
    Currently what I did was execute the file Sygic Mobile Maps India V6.0.exe from a rar file Indian_Curry.rar and installed it on my PC. Using the installed software I copied the Software onto a SDCARD. I inserted this SD card onto my GPS DEVICE and then ran the installation to get the Device ID. I then used the Device ID with the KeyGen (on PC) and MLM file ("MapmyIndia All India Street Level Map Version 6.0.mlm" and "MapmyIndia All India Street Level Map Version 4.1.mlm") to generate the activation code.
    What should I be using to get the latest Maps and Software with 3D? Any help would be appreciated. The user Ariion's posts were of immense help. Thanks a lot for that.
