Importing custom poi icons
Sygic Fleet 10 V8.30 on WinCE.
I have converted my old TT Ov2 poi's to Upi and put them in the maps\gbr folder on the SD card.
These work fine, but I can't get custom icons to work. I have used the 32bit bmp format that Sygic says they must be in, used the same file name as the upi file and used the prefix number for size eg: 3_poi.bmp. I have tried placing the icon files in the maps folder and Res folder, but they are still not visible. Instead Sygic uses a grey "?" symbol to show them on the map.
Any suggestions please??
23rd March 2012, 20:32
#2
Re: Importing custom poi icons
the grey ? means that within the POI file (UPI) is also written the name of icon in BMP
Use this program
Sygic General Discussion
23rd March 2012, 20:33
#3
Use this program
25th March 2012, 21:06
#4
Thanks for the reply, what programme? the link just takes me to general discussion page. Any help gratefully appreciated.
