Thread: Sygic 11.2.6 problems in Android 2.2 GPS
    kkc153 is offline Private
    Feb 2012
    I installed 11.2.6 in a chinese gps called Eroda T7. Whenever I try routing, the programme would stop, sometimes after a few seconds, sometimes after 30 seconds. The tablet's home screen will appear. But when I let the programme run without routing, then it is stable. Thought might be a memory problem, cleared half the tablet to allow 4G in the internal flash. Same results. Any idea how to fix this? The same programme runs ok with routing in my samsung I-9003.
    3,132
    223
    Re: Sygic 11.2.6 problems in Android 2.2 GPS
    It is the problem of your too low ram. 256mbs - 512mbs
    Version running v2.3.3 and above is recommended.
  3. The Following User Says Thank You to Airion For This Useful Post:
    Troy44 is offline Corporal
    Feb 2011
    27
    Works fine with android 2.3 and higher so upgrade
    ZakelijkThuis.nl
    thnxx
  5. The Following User Says Thank You to Troy44 For This Useful Post:
