Thread: Sygic MM10 uk speed cameras
    Milerpa is offline Private
    Can anybody point me in the right direction to get up to date UK speed cameras as POI's ?? thanks
    Re: Sygic MM10 uk speed cameras
    it appears tomtom purchased sygi, file system used is ov2 go here its in their list of supported systems. jez
    Essex UK
    209
    I thought sygic used txt files, if it is ov2 then there are some ov2 files in the tomtom poi section of this forum, they aint the most up to date but april is better than nothing and they are free.
