Page 2 of 17 FirstFirst 123412 ... LastLast
Results 11 to 20 of 168
Like Tree3Likes
Thread: Sygic Drive problem disscussion
  1. #11
    FatLeo's Avatar
    FatLeo is offline Corporal
    The Netherlands
    18
    Re: Sygic Drive problem disscussion
    I have download the Australia map en mlm file and placed it in the Sygic maps file and it works fine for me.
    Maybe the problem lies in the Australia mlm file ( [AUSTRALIA] instead of this [AUS]
    I've used the Europa.mlm file and this works.
    This is how the Europa.mlm file looks like:
    [DEFAULT]
    version=1.2
    majorVersion=7
    freeTmcs=10@1; 4@9; 6@1; 13@1; 1@1; 9@9; 14@17; 5@1; 8@17; 15@49; 14@33;
    [WORLD]
    provider=TA
    mapRelease=2009.03
    detail=full
    7digitPostals=yes
    tmc=yes
    speedcam=yes
    speedCamRelease=2009.03.05
    [NAMERICA]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [UVI]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [NLD]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [BEL]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [LUX]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [AUT]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [CHE]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [DEU]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [AND]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [DNK]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [FIN]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [IRL]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [LIE]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [MCO]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [SMR]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [VAT]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [WCL]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [NOR]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [SWE]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [GBR]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [PRT]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [ITA]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [FRA]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [ESP]
    provider=TA
    mapRelease=2009.03
    detail=full
    tmc=yes
    [CZE]
    [CZK]
    [EST]
    [HRV]
    [HUN]
    [ITU]
    [LVA]
    [MNE]
    [POL]
    [ROU]
    [RUS]
    [SRB]
    [SVK]
    [SVN]
    [UKR]
  2. #12
    3,132
    223
    Thanks for your good post. Maybe others can follow the example. Having hard time explaining the details to the andriod users.
  3. #13
    FatLeo's Avatar
    The Netherlands
    18
    My previous post is not quit right.
    The mlm file was tested on my laptop (Sygic Drive Mobile V7.71) but when I tried that same mlm file in my portable navigation (Navman F10) it did not work (Sygic SMM10).
    Here is the right mlm file for the SMM10 found on the WWW.
    [PRODUCT:SMM10 World]
    name=SMM10 World
    tts=no
    sdk=no
    truckAttr=no
    premiumPOI=no
    exPostals=yes
    speedcam=SCDB:World:2012.03
    maps=TA:World:2009.11
  4. #14
    kuailan is offline Corporal
    22
    I know it must have been the mlm files that is a problem, cause I can activate the European map ok. By the way FatLeo, what do you have in your Australia mlm files?? maybe I can just copy them over the same thing, and maybe it will work??? Also what is that SMM10 World mlm thing?? you mean it will activate the whole world map??
  5. #15
    FatLeo's Avatar
    The Netherlands
    18
    The SMM10 World.mlm will activate the whole world, I’ve tried it and it makes no difference witch country you will use.
    Remove all mlm files and replace it by the SMM10 World.mlm file.
  6. #16
    3,132
    223
    Quote Originally Posted by FatLeo View Post
    The mlm file was tested on my laptop (Sygic Drive Mobile V7.71) but when I tried that same mlm file in my portable navigation (Navman F10) it did not work.
    name=SMM10 World
    tts=no
    sdk=no
    truckAttr=no
    premiumPOI=no
    exPostals=yes
    This mlm file is meant for PDAs and Not for PNDs. Note that the sdk is no, tmc not available, text to speech - no,. premium POIs also no. PND don't have this problems.
    PDAs are not really suitable for GPS navigation. There is software restrictions inside which cause problems to real time navigation.
    This is what I used in my PND
    [DEFAULT]
    majorVersion=7
    sdk=yes
    [SEA]
    provider=TA
    mapRelease=2009.11
    mapdetail=full
    7digitPostals=yes
    tmc=yes
    speedcam=yes
    premiumpois=yes
  7. The Following User Says Thank You to Airion For This Useful Post:
  8. #17
    22
    Well cant he just edit those NO into Yes instead on the world.mlm??
  9. #18
    3,132
    223
    Well well well you try it out and see
  10. #19
    22
    OK I finally get my Australia map working good....here is what you need in your Australia.mlm
    [PRODUCT:SMM10 AUSTRALIA]
    name=SMM10 AUSTRALIA
    tts=no
    sdk=no
    truckAttr=no
    premiumPOI=no
    exPostals=yes
    speedcam=SCDB:EXTEUR:2012.03
    maps=maps=TA:EXTEUR:2020.12,TA:AUSTRALIA:2020.12
    Just copy and paste the above to make your own Australia.mlm and then just activate it using your keygen.
  11. #20
    22
    Quote Originally Posted by kuailan View Post
    tts=no
    sdk=no
    truckAttr=no
    premiumPOI=no
    exPostals=yes
    OK I have tried the setting above, but this time with TTS= yes, SDK=yes,all the rest = yes, and IT WORKS JUST FINE!
