Thread: Postcode routing...
    Robiko is offline Private
    Postcode routing...
    Hi all, had installed Mobile Maps 10 version 8.06/maps 2008.10 which had a postcode routing, just upgraded to version 8.22/maps 2010.07 and the postcode routing has gone...any-one have a solution for this please?
    Re: Postcode routing...
    I am having exactly the same problem. Was using 8.06 and when moved to 8.22 the postcode icon doesn't even show.
    tonyw is offline Corporal
    Jan 2011
    Nederland
    18
    I am having exactly the same problem. I am running 8.22. Now i am going back to versie 8.16. Please let me now if any body has a solution.
    Now i have running versie 8.24 and everything went wel. so you can better thake this versie from this site.
    shadow20 is offline Staff Sergeant
    60
    34
    check to see that you have the following in your settings.ini file
    [Settings]
    UsePostals=true
    My solution was to go back to version 8.16 and enable 7 digit postcode in the mlm file...
