Rename Drive/WindowMobile to Drive/WindowsCE
Then as follow by Drivers/Default
There will be no error.
sorry ! already installed on my gps (atlas 600mhz, wince6, 128 mb) pop out this messages ; "the software performed illegal instruction(main). we are sorry for inconvenience ! si not work !
sorry to ask...
how to create mlm file in map folder?
Very strange, I got the same error when I used a 2GB and 8GB microSD card but a 4GB card work OK with no such error using the same software copy. I have a Chinese 2DIN 600mhz, wince6, 128 mb unit.
Could someone else confirm this? The 4GB card was the card I used to activate Sygic initially. Can I just copy the software to another card without having to activate it again?
Very strange indeed.
Your save data and settings are there on the 4 GB.
v8.22 is not a good version to use.
It is modified from Indian Sygic version.
Recommend to use Sygic Truck version 8.30
No such nuisance
Log on and navigating is good.
What is the latest Sygic version for WinCE?
Is there a WinCE version which supports TTS?
Cheers.
Hey,
i bought wince 6.0 2 din player from china. i am not able to run GPS as after clicking on GPS menu nothing is happening..how to give path of new sygic application ???
http://www.chinavasion.com/2-din-car...with-gps-dvbt/
can you hepl
