Hi all,
Sorry for the Noobie question.
Could someone show me a step-by-step on how to install Sygic Mobile 10 8.22 on Chinese 2 DIN Car GPS running WINCE 6 128MB?
I have tried to install TomTom on this unit and apparently TT has problems running on 128MB units. So now I am trying Sygic instead
The unit is running iGo8.3 but the maps and speed limits don't match in real life
Thanks.
Did u mange to do it or should I show u how to it???
No, I still have not been able to get it to work![]()
Download software from thread.
Transfer it to device or sd card. No installation required for WinCe.
Put in your wanted maps in map folder
Create mlm and license as accordingly with your device software ID
Read the sygic file system for more information.
If there is other problems - write again.
i bought a car dvd/gps system for my car recently and successfuly installed Sygic 8.24 and Sygic fleet 8.30 on it.. if u need help let me know.. i had a few problems at beginning too.. but all good now..
My WINCE 6 CHINA PND shows language option on running drive.exe but cannot select a language. Nothing happens after that, I cant even exit. Please help
Thanks[/QUOTE]
Check the software folder/RES/Eula
What are the eula files inside.
Your wanted language might be missing.
