Thread: Mobile Maps 10 - Android, closes instantly
    I'm using an Orange San Francisco phone with a Froyo 2.2 rom. I've installed Mobile Maps 10 and added a GBR map. On 1st load, Mobile Maps goes through the initialisation process and then asks me to register my mlm file which I successfully do (it tells me map is activated) using the keygen. It then closes and throws me back to my android home screen. Every time I try to load up the Mobile Maps 10 app it shows the loading screen then closes and throws me out.
    Any ideas?
    Re: Mobile Maps 10 - Android, closes instantly
    Same happends to me using a samsung galaxy s with froyo. It might be an error from a previous install, I uninstalled and reinstalled but no joy. Any ideas how to uninstall this and remove any traces of it?
    thank you!
    Problem solved!
    The file licence.txt needs to be deleted from the maps folder. Sygic writes something with "trial..." in it and because of this it gests closed.
