Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Sygic Mobile Maps para Bada
    rj12 is offline Sergeant
    39
    23
    Finally we have available.
    To install it correctly, you have to have configured the applications are installed on the memory card. (settings - applications - installation settings - memory card)
    The first thing you have to do is get off of the mobile SamsungApp sygic Greece.
    Once downloaded and installed, run it to see what works. Do not try to activate the map that you can not. Give to remember later.
    Now close the sygic and connect the phone to pc in mass storage mode.
    We follow the route memory card / others / _ @ @ bada_apli.../c0h9tw1o08/res/maps and delete everything in it and replace it with the next in this file. (The folders PST, wlc, license.txt and Navteq 2010-04.mlm)
    http://www.mirrorcreator.com/files/13O5SXIO/bada.part2.rar_links
    http://www.mirrorcreator.com/files/GWTCKNBR/bada.part1.rar_links
    Now disconnect the pc the phone and start the sygic.
    We ask you to turn on a map and we have to select the manual mode, not the Internet.
    We give a code that begins as BADASIM **********
    Download the Keygen to get the code for your device
    Now open it and in the field MLM File select the file. mlm map we downloaded.
    Device ID field, put the code on the device leaves us. With BADASIM ********* including
    Mark the box just below the Device ID and set this Check if You Have version 8.16
    We would like to generate and insert the code that gives the Keygen in the mobile and ready
    Got it activated and working.
    tomcsi01 likes this.
  2. The Following 5 Users Say Thank You to rj12 For This Useful Post:
    Feb 2011
    Re: Sygic Mobile Maps para Bada
    Where can we find maps and how to install them?
    Thank You in advance!
    39
    23
    are the same maps that android or symbian version.
    http://gpsunderground.com/forum/sygi...teleatlas.html
    Feb 2011
    Can i activate the cyprus map that is already downloaded in the app ? If yes what changes should i need to make to the folder?
    39
    23
    do not have to make any changes once you have activated the product may be put the maps you want.
    Greetings.
    Feb 2011
    Activation is ok. But when I copy other maps it doesn't show them when I turn on Sygic in the phone. Only Spain... What I have to do to be able to see other maps?
    Feb 2011
    is it just my phone? or this app is so slow?
    39
    23
    no, I can not I have a htc dicir desire.
  10. #9
    39
    23
    Before isntalar gets all the maps in the folder and then activate mpas application.
  11. #10
    Syfer is offline Private
    Ive tried it yesterday with map of Portugal on a plus 100 km drive , and in terms of options and the quality of the interface is far better than ndrive or route66. Very fast getting gps signal even in doors, but after having signal it becomes very very very laggy, when navigating through the menus, or refreshing the map while in course. All the informations are correct, but delayed.... I'm on firmware JID bada 1.2 at the moment, didn't liked some stuff on the last official one.
    To use other maps follow the link rj12 said, and don't forget to change MLM content in notepad, and activate using the new MLM
