Tried installing sygic nav from play store
Took 2 hours downloadin 238.6mb.
After all is downloaded nothing stops ...
Seem to have everything ???
But nothing stops.
Waited for another two hours...
Hit the sygic icon.... A. Other sysgic app starts with only option to stop. For few seconds an advance icon.....
Them then just message to br patient...
Waited for hours no change
Retried after full deinstall and eraise of sygic directory.
On a blank fresh intalled android.
Re installed everything ... With exact same result..... Just wasting for hours.... Nothing
Advances..... Seems like a crappy apk...
Other apk's seem to install without any problem. Only sygic nav from playstation locks up completely......
After 4 attemps .... No change
Crappy spk ????!!! do I miss something ?????
never saw any option to doownload maps ???
Enthusiastic Gio User
Very glad with the work done
But sometimes a pusher for results( nothing bad intended)
7Likes
LinkBack URL
About LinkBacks
