Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 41
Thread: Traffic (TMC) Reception for Sygic Drive
  1. #11
    Re: Traffic (TMC) Reception for Sygic Drive
    Danke für die Info´s.
    aber seit der Änderung schlägt die Aktivierung fehl. WAS NUN?? kann einer helfen???
    DANKE
  2. #12
    Sorry, i´m not sure how to edit system menu settings. Plz explains for a noobie. Thanks.
  3. #13
    bobbecek is offline Private
    Thanks for a nice guide how to activate Traffic/TMC.
    I have followed all instructions and I only have problem with connecting to my GNS TMC BT receiver and/or external Qstarz BT GPS.
    I'm running Android 2.1 and the auto-detection does not work (it finds internal GPS only). When I try to setup the connection manually, there is no list of available (paired) bluetooth devices and the COM PORT setting has two options (1) android (connects to internal GPS) and (2) user defined - here you are asked to put a name of COM port.
    Could anyone help with connecting to external GPS/TMC receiver on Android device (HTC Hero)?
  4. #14
    3,132
    223
    Quote Originally Posted by bobbecek View Post
    Most TMC devices operated on Com1.
    Check the operating baud rate of your BT receiver.
    Assigned TMC port and baud rate to phone by asssign setting.
    Turn on BT and TMC receiver. Paired them.
    After pairing - turn on software and proceed to TMC settings.
    Key in the receiver code to activate the receiver.
    Get the signal codes for your country and specify them in your mlm file.
    Recreate license text and save.
    Test for Signals during navigating.
    Ensure that your TMC receiver and GPS does not share the same com port.
  5. #15
    Could you please explain more detaily?
    How do I assign TMC to e.g. COM1?
    How to do the rest?
    Thx
  6. #16
    3,132
    223
    How to do the rest?
    Thx
    Turn on your BT and paired the receiver with your phone.
    Turn on software = setting/ traffic/setup
    Manually enter comport and baud of receiver.
    then save.
  7. #17
    then save.
    Yes, I know what you're trying to describe. BUT what are the names of the COM port being used by my paired BT devices (ext GPS receiver, ext TMC receiver)?
    "COM1"? "COM,1"? "COM-1"?
    "COM2"? "COM,2"? "COM-2"?
    I have been trying to put all possible alternatives, but the result is still BIG NOTHING. I am afraid that the Sygic Drive can work only with devices listed in the relevant menu, which means, in my case, internal GPS only (the COM port named "android")... :-\
  8. #18
    3,132
    223
    You can to check the mlm file whether the TMC=yes
    Add in the TMC codes and regenerate the licence text.
    Next ensure you have the TMC files in your drive directory
    (ex - TMC.dll , the receiver TMC working dll and your area signals dll files )
    You need all this to work
  9. #19
    1. mlm file is ok (TMC=yes)
    2. licence done
    3. TMC files in place
    I think that the "COM port assignment" should be done by Android system (after pairing the device) and Sygic Drive should simple list available devices in the manual config screen... but something in this procedure is obviously not happening
  10. #20
    3,132
    223
    If your sygic TMC or traffic icon is not grey means that you have configured correctly.
    Just click and go for autodetect com port and baud.
    If grey - then your setup is wrong. Hardware problem.
    Can't explain much on that - no set to test.
    Maybe you can try this
