TMC software for Sygic Drive. Unzip and copy to drive. Edit system menu settings and mlm file and recreate license to activate receiver and map files.
Edit mlm file-
Set tmc=yes
Set tts=yes
Edit menu -
[menu.main]
menu.main.traffic=1
[settings.menu]
menu.settings.leftHanded=0
menu.settings.rightHanded=0
menu.settings.backlight=1
menu.settings.gpsLogs=1
menu.settings.gpsStatus=1
menu.settings.trafficStatus=1
[menu.settings.hardware]
menu.settings.hardware.wizard=1
menu.settings.hardware.baudRate=1
menu.settings.hardware.gpsOn=1
menu.settings.hardware.comPort=1
menu.settings.hardware.sync=1
menu.settings.hardware.autodetect=1
[menu.alternative]
menu.alternative.traffic=1
Support only GNS signals
Nice post !
Thanks for this Sygic v8.0.6 TMC files.
Updating my older v7.7.1 version.
Works well with better reception. Only my country has limited signal sources.
You must be another regular Sygic user.
Do you have the SDK / API newer version than v7.50.229 (2008) logistic data layer for advance navigation.
Thanks in advance.
SYGIC has really old info on states....for example my country CURRENCY is EUR 4 years now, geeze.
and how to get TRAFFIC icon active, now it's grayed.
This indicates that your tmc receiver is not active in navigation mode
1} maybe you have to check your mlm file whether the tmc is set to "yes"
2} your gps hardware setting on tmc reception is wrong - check the com port setting, the baud rate set to your country and the type of signal.
Set them to your country GNS signal network reference. Some homework to be done to get it working.
3} After setting, make sure you pay up your subscriptions and to enable reception. GNS will control incoming and outgoing signals as accordingly to your TMC receiver 10 digit code. If not you will receive nothing even your tmc is active.
airion yes that...
i have HTC DESIRE![]()
hi Airion
My SDK is preloaded in my PND. If you want it - I will copy them for your reference. No idea which version was it but it works all well. Send to you later.
Maybe you can check the SDK latest version with Microsoft on WinCE together with API functions.
Thanks. Looking forward to it. I think that you are a real pro or high time user in Garmin and Sygic too
