Please check this web page for basic settings of Sygic Drive
http://www.sygic.com/en/support
hi,
the link is dead
bye
Sygic has change their support to this
Sygic | Support
where can I find full description for Aura 'settings.ini' file ?
Any suggestion ?
To clarify my request, I would like to change all settings of this file.
Here is an example of the beginning of a 'settings.ini' file :
[Application]
title=Sygic AURA
homepage=http://aura.sygic.com
memory=high
; use memory=low if the device has very limited amount of program memory
;swVersion=2.0
; Define custom splash screen
;splash=_Your_Splash
; topMost=true -> no other application will appear above navigation
; topMost=false -> other applications (e.g. MP3 player) can be displayed above navigation window
topMost=false
; Other values read by code:
;colorMode
;cpu
;cash
;splash
;sdcard
[Drivers]
; Select driver (defines assignment of keys, backlight, com port handling and more)
Driver=Default\Driver.dll
; Do not use the below
Device=Default\Device.dll
[Default]
; com=[COM7:,9600 | autodetect]
com=autodetect
;tmc
tmc=COM4:,38400,3
[Settings]
RouteComp=enable
;DPI=192
;Ballance ratio between DPI and Screen size (0% - 100%).
;if BallanceRatio=0, DPI is ignored and Screen size has full weight.
;if BallanceRatio=100, Screen size is ignored and DPI has full weight.
BallanceRatio=50
For some parameters it's very easy to change (true or false values).
But for others, required values are numeric or alphanumeric and there's no example for the exact syntax, or the value range tolerated.
Therefore impossible to know or deduce what to put...
Does anyone have a complete 'settings.ini' file, with all the associated help ?
Or an exaustive documentation explaining all these parameters and possible values ?
Thanks in advance !
On what device are you apply the changes?
Thank's for your reply !
I've wrote another post with complete explanation and examples from a 'settings.ini' file, but it was under 'control moderation' and not displayed ? (I don't know why ?)
It's on a Wince device unit, but after comparing with other versions of Aura (or Sygic, MMI, ...) and other unit (Android) it's pretty close...
My wish : I want to know all the possible parameters and values for each section of this file.
In some cases, values are obvious: true or false.
And in other cases, the choices are less evident to deduce because the result can be numeric or alphanumeric.
At last, there are parameters that I can't fill because I don't know the syntax :
- choice list for battery management
- choice list for radar warning sound or speed warning
- and many mores...
I am looking for a detailed description of all possible values of the parameters contained in settings.ini file.
Thanks in advance ;-)
