Thread: TomTom GO700 Battery
    My GO700 battery is very weak. Holds power just 20 minutes. I have seen, on the old forum, how to change the battery. But does someone know where to find the correct battery - not too far away from Sweden (at a reasonable cost)?
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: TomTom GO700 Battery
    google? ebay?
    matt_mel96 is offline Corporal
    Sydney, Australia
    19
    Entering 'go 700 battery' into Google shows a website called 'GPSforless' which advertises battery for £12.98 (£11.05 ex VAT) from the UK. I wouldn't think postage would be all that expensive.
    enviedenigma is offline Lance Corporal
    my tt700 keeps turning itself off even with power lead plugged in, is there a problem with the battery???
