Thread: [solved] TomTom GO910 map Help
    Smile [solved] TomTom GO910 map Help
    Hi I own a old tomtom go910, i have downloaded West&Centr_EU_2GB_845_2647, I placed it on the root of tomtom and used easy activator to register it
    I updated the meta file and got no error during the process, but when i turn on my tomtom i can not see the new maps.
    Does anyone know what to do?
    Thanks Alot
    Melvinand
    Hazzing's Avatar
    Hazzing is offline Sergeant First Class
    Denmark
    114
    Re: TomTom GO910 map Help
    You probably have to patch your navcore, the way I see it. Go here http://gpsunderground.com/forum/show...-keygen-tomtom and use the yDGpatch tool to patch your navcore.
    Here http://gpsunderground.com/forum/show...aps-vs-Navcore you can see which navcore goes with your TT and also which map is compatible with which navcore.
    That is just if you have to update your navcore, but I think patching it should do the trick.
  3. 25th May 2010, 07:23
    Banned
    Sorry I“m slow i have not been able to try it since im not at home and havent been since i postet the question. But i“ll try it tonight and give some feedback as soon as i have tried.. :-)
    But thanks so far for posting me some help!
    Hazzing's Avatar
    Denmark
    114
    You're welcome.......hope it helps you
    Yhanks alot, i patched my navcore and it works just perfect right now.
    Hazzing's Avatar
    Denmark
    114
    Glad to be of help c",)
