Results 1 to 10 of 19
Thread: Need help pls!!
    alexalin2009 is offline Lance Corporal
    Need help pls!!
    I Have aTOMTOM ONEv8..ApplicationVersionVersionNumber=8010,BootLo aderVersion=55011 and i wnt to install a map(wester and central europe 2gb)on onternal memory of my tt...i patch the ttsystem with ydgpatch but i dont know wat type of navcore and map i need to instal..thx
    Sitting at my computer UK
    Re: Need help pls!!
    Quote Originally Posted by alexalin2009 View Post
    I have a TomTom GO 300, depending on which SD card I use it thinks it is a TomTom One! These are my settings:
    App 8.410
    GPS v1.20
    Boot 5.5120
    Map UK & RI v845.2645
    I hope this is of help.
    HolidayBob
    Re: Need help pls!!
    thank you for help
    Re: Need help pls!!
    i downolad the map europe 845.2647 2gb,i extract the files with hjsplit and i right know i have a single file large (1.543.017.202 byte)..what do i have to do next..thx
    Re: Need help pls!!
    witch tool..thx
    paulsmith6 is offline Banned
    45
    Re: Need help pls!!
    Unzip the map copy and paste to your device something like, united_ kingdom_ri download the software to unlock your navcore and maps etc easy or better still read a tutorial on how you do it, always make a backup of your original,
    Re: Need help pls!!
    i done this but it say that i dont have enough memory to paste the map...
    Re: Need help pls!!
    my tt dont have SD...My device has internal memory..thx
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Need help pls!!
    Isn't this one with 1GB internal memory?
    rgds jarkita
    Re: Need help pls!!
    No,i have version with 2GB internal memory
