Thread: Problem with TomTom Go 300 and Western and Central Europe 2GB
    tomtom3 is offline Private
    I'm using a TomTom Go 300
    Serial Number M1****C*****
    ApplicationVersionVersionNumber=7903
    ApplicationVersion=9183
    BootLoaderVersion=48600
    trying to install map:
    Western and Central Europe 2GB(8.45 2645 1.84gb) on SD card (2 GB)
    tried keygen and navcore
    with Easyusetools 11-1-10 -> doesn't work : "Map not found" is displayed on device
    and with TomTom Keygen v2.1D -> doesn't work : "Map not found" is displayed on device
    keygen seems to work each time but I guess there is a problem with the navcore. Any suggestions?
    Thanks for help
    Re: Problem with TomTom Go 300 and Western and Central Europe 2GB
    Sorry, do I need another map or is there another keygen / navcore generator?
    Other question, where do I find the compatibility table?
    Thanks for your first quick responds
    Thanks alot!
    9026_one.rar seems to work. Fine
    Now I have to figure out if everthing fits on 2 GB ;-)
    Thanks a lot!
    Everything works fine!
    gmhr is offline Private
    Quote Originally Posted by tomtom3 View Post
    Thanks a lot!
    See you had some luck with your Go 300 , can I can ask what did you use Easy Activator.
