Thread: problem with go 930 in navcore 9.101.516023
    Question problem with go 930 in navcore 9.101.516023
    Thanks for all information in this forum.
    I just bought a go 930 going with maps in west Europe and north america.
    I tired voice recognition and it worked well.
    After that, I tired to use navcore 9.101.516023 with the map [Australia][845.2661][with IQ Routes].
    Both of them are downloaded from the link found in forum.
    I have ASR folder including files for English language and cspeech_AUS.dat in map folder.
    But i could not use voice recognition when address setting.
    Any advice?
    Thanks a lot.
  2. The Following User Says Thank You to cliro For This Useful Post:
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: problem with go 930 in navcore 9.101.516023
    Does it work with "original" patched (or SE) navcore?
    well, basically, the device works fine.
    I can't figure out whether navcore or map has some problem or just i made wrong configuration.
    I would report later after doing some testing.
    Mod edit: Just test with [North_America][2GB][845.2645].
    voice recognition works fine.
    I just wonder to know the cspeech files in map [Australia][845.2661][with IQ Routes] could support voice recognition in tomtom when address setting?
    Is there any other person using the map [Australia][845.2661][with IQ Routes]?
    sazzadhasan is offline Private
    Sydney, Australia
    I've created this link "map [Australia][845.2661][with IQ Routes]" and I'm using this map with my Go 930. I never had any problem with voices. Thanks...
