Results 1 to 7 of 7
Thread: [solved] Help with 845.2702 & GO910
    Allybee is offline Private
    Hi All
    I've been trying to update from map western & central europe V660.1219 to Europe 845.2702. I've applied Keygen & patcher and they appear to work ok but I'm not seeing map in list when I reboot TomTom.
    Is there anything else I should be doing ??
    I've reinstalled original map & ttsystem and now I'm back to the following:
    App 7.903
    GPS V1.21 Boot 4.860
    Map western & central europe V660.1219
    Thanks in advance
    Allybee
    Re: Help with 845.2702 & GO910
    Hi Allybee
    You need to update the navcore on the device ... (App 7.903 will not read 845 map)
    SE Navcore 9.101.516023 works fine on the 910 found here
    You will lose auto switching between day / night, but the rest should be fine
    Just make sure you keep the backup you have, also try the new navcore WITHOUT placing the "system" file (bootloader) on your unit. Always a good idea not to upgrade the bootloader unless you have to.
    enviedenigma is offline Lance Corporal
    I've tried to install map 845.2647 and it keeps saying no maps found when I re-boot I've used alberts easy activator
    I've reinstalled ttsystem and now I'm back to the following and unfortunately didn't back my original map up so now I've got no map otherthan this new 845.2647
    go700
    App 7.903
    Bootloader 55120
    Hi Pacman
    Thanks for your reply, could you please advise how to use these files. Sorry to be so thick
    biosfix is offline Sergeant
    52
    29
    See this table, you need 9.02 Navcore to read the map.
    I made same mistake before.
    http://img504.imageshack.us/i/845k.png/
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Quote Originally Posted by paccman View Post
    Hi Allybee
    Not entirely true ... 7.903 reads 845 maps ... lower end ones
    Quote Originally Posted by enviedenigma View Post
    go700
    App 7.903
    Bootloader 55120
    Did you patch ttsystem aswell?
    rgds jarkita
    Hi All
    Thanks for your help. Just to let you know I managed to get map 845.2666 and with app 7.903 it updated a treat. Now working fine.
    Thanks again for help
    Allybee
