Thread: tom tom go700 battery replacement
    enviedenigma is offline Lance Corporal
    Any ideas as to how to change the battery on one of these??????????
    Dutch Mountains
    285
    Re: tom tom go700 battery replacement
    There is a guide here:
    http://www.fixya.com/support/t586428-battery_tomtom_700
    Be advised that you need one or more Torx screwdrivers (at least n.6 but for the harddisk also n.7 and 8). Some battery vendors sell a replacement battery with included Torx screwdriver.
    When you start this operation, it is a hell of an opportunity to also replace the 2,5 GB Seagate Microdisk with a 4 or 8 GB CompactFlash card.
    Why?
    - The 2,5 GB drive essentially is a hard disk with moving parts. It can break down, it is slow and it is not that big any more these days.
    A modern CompactFlash card is faster (get a 133x or faster one), bigger and consumes less energy because of the lack of moving parts. See it as a Solid state disk upgrade to your TomTom.
    The most used card for this would be a 4 GB Transcend 133x card and here are the instructions:
    http://web.mac.com/hahnenuk/TomTom/Go700_CFCard.html
