Thread: [moved] TomTom Start 845.2666 Scandinavia problems
    Finland
    Hello all, I'm new here on forums.
    Device Type: TT Start
    AK*** A****
    8,544 (1836)
    Bootloader: 5.5234
    Map Scandinavia 845.2645
    Pc: Windows 7 x64
    A new map (Scandinavia 845.2666) & Easytools are both downloaded to my desktop.
    I opened the meta.txt file inside the easytools folder, but apparently the 845.266 version cannot be found in this txt.
    What should i do?
    Sincerely
    Max
    Ribes is offline Private
    Re: TomTom Start 845.2666 Scandinavia problems
    Have you updated meta.txt ?
    1C 5D 6A 76 C2 2F 41 EC E4 88 14 FE AA 50 BF F1 Scandinavia-140.meta
    ; Scandinavia 845_2666
    Finland
    I did all the steps with a updated meta.txt as instructed --> http://gpsunderground.com/forum/show...it-from-basics
    When i ran the Runmeforallautomatic script it did not unlock the map at all. Something went wrong and my TomTom did not start/shutdown anymore. I did a reset & restored to the earlier version with old maps.
    Sorry for bothering, but is there something that can be done to get this new software (845.2666 Scandinavia) to work?
    Edit: When i copy the 845.2666 map to my Tomtom and open TomTom Home 2 it starts searching for updates. It finds newer maps than the one i downloaded (845.2666).
