Results 1 to 7 of 7
Thread: Poor gps signal....r u in a building
    Hello glad to see the new underground up again.
    I have a problem and cant seem to figure it out. I have a ttxlone with navicore 9.051, map 845.2645, 32ram with 4.5mb free.
    I have 8 to 10 bars in grey color and the unit says no gps signal are you in a biulding. No matter how far I drive the TT does not go to blue bars.
    I have done the following
    hard reset
    soft reset
    reinstall with above back up
    reinstall with old back up
    all gps fix updates
    and clear fix.
    Still 8 to 10 bars and no signal.
    Any suggestions
    Thanks in advance.
    lake city fl
    Re: Poor gps signal....r u in a building
    i suggest you send it back the receiver antenna inside probably gone bad good luck
    Do you think an external antenna would help.
    Question Re: Poor gps signal....r u in a building
    I have a similar problem, My dad brought a 2nd hand sold as faulty tomtom one. I assumed with a new navcore and maps it would have fixed it but nil result so far.
    It does find satellite's but not as many as my tomtom one, it will find upto 3 within around 30mins (if lucky), but the bars will not turn from grey to blue, even when the bars are full!
    When it did lock, witch as only ever happened once in a blue moon, its been attached to my loft window and left alone. but soon as I come down to normal ground, it loses it's lock again.
    Like I said, I've tried various different navcore's, hard reset, soft reset, clear the tomtoms cash, quickGPS fixes. And no improvement.
    I was just wondering, as it can find sats but not many and have full grey signal, plus is still able to get the UTC signal. Could the internal aerial be dead/dieing?
    And would it be worth trying an external one?
    Many thanks and sorry for rambling one lol
    Dave
    ato's Avatar
    ato
    ato is offline Corporal
    16
    48
    I dont know what kind of device you all use. My TT Go 710 (mainly after a satellite quick fix update with tomtomhome) can find 4-6 satellite also inside my house. So your problem should be pending on your device type.
    Go 710, nc 9.101.516023.2, Europe.v.845.2670, Boot 5.5259 on 16 GB SanDisk Ultra SDHC card
    hi
    thanks for the reply, its a tomtom one v4. I have done every update that tthome downloads just at the hope it might lock on, but still nothing.
    dave
    strange aswell, only time I ever do get a lock is when I stick the tomtom to my attic window, as per picture. which is 3 stories up. but back on open level ground nothing? Im sure the internal antenna's had it?
