Results 1 to 7 of 7
Thread: Read..important.read.important.read
    paulsmith6 is offline Banned
    45
    Thumbs up Read..important.read.important.read
    Anyone with recent navore updates and maps cracked from here or any other site do not update via tomtom home, gps correction update, or navcore update will render your maps unusable. You have been warned. Get poi etc all day long even map share corrections but not updates. updates
    itilley's Avatar
    itilley is offline Corporal
    UK
    22
    16
    Re: Read..important.read.important.read
    OK = So when did this start as I updated my UK map with the gps correction update 3 days ago with no apparent problems. I think we need more specific information and further confimation of this report and if it is completely correct it should be at the top of the list as a Sticky.
    Sorry to be not convinced as yet.
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Just updated MapShare & QuickGPSFix as usual (with no loggin in). Device works as before
    rgds jarkita
    brickan is offline Lance Corporal
    sweden
    Uppdated my tomtom to day and there was no problem :-)
    Quote Originally Posted by paulsmith6 View Post
    Navcore .. of course, because you'll need to crack it again.
    GPS corrections ... what a load of crap.
    Dutch Mountains
    285
    What Paul means is, do not accept the "TOMTOM APPLICATION" when it is offered as an update. Tomtom will offer this when you have not properly protected your Navcore SE with a version.txt file.
    Inside the Readmenot file there are instructions on what to place inside the version.txt file. It is a representation of the last known good version by Tomtom for your version.
    Exemple: You connect a Go 700 to TTHome, it will look in your ttgo.bif file if Navcore 7.903.9183 is installed. If you are running 8.562 SE, TTHome will offer you the unpatched 7.903 as "Tomtom Application", thus rendering your Tomtom unable to read your maps again.
    However when you create a file version.txt in the root of your Tomtom with in this case
    A:7903
    B:9183
    These values will be written inside your ttgo.bif file and the dreaded Application update will not be given. (Still, if it is offered, you are free to refuse it, only it is easy to miss).
    All other updates (mapshare, voices, map colours, car art) are safe.
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Quote Originally Posted by heijx View Post
    Even if update somehow gets in, it should not be a problem to fix for someone who already did crack on his device ...
    Edit: Have now included a warning notice in "patching" tutorial.
    rgds jarkita
