Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Help with G720 plzzzzzzzzzz
    TaNk is offline Lance Corporal
    Hi Guy's
    I had navcore 8351 & North_America_835_2419 map .. i just updated my TT to Nav 9.101 & current 2010 N-America Maps & i lost my , Light Camera's , Route IQ , Lane Assist & Hands free speak thing where i just press the button & speak my address in ... don't care about anything else just need Light Cameras & Hands free address thing .
    can anyone plese help me with navcore which one to use? i tired 8.562 and still didn't get camera's & hands free address input.
    Thanks alot .. i need this for my work tomorrow guys
    Again Thanks
    steve uk's Avatar
    steve uk is offline Sergeant
    41
    Re: Help with G720 plzzzzzzzzzz
    Did you or have you got a back up of your device. if so copy all the files back to your tt.
    navcore 9.026 would be a more favourable one to use although 9.051 may also work. the ALG and IQ routes are down to the map version.There is a sticky on the map section showing which maps have what features obviously 835.2419 does not have ALG or IQ routes.
    latest maps are 845 try the 845.2645 in the map section. The speed cameras would have been in your old map folder so you need to copy them to your new map when you have one with the features you require.
    Thanks for reply Steve,
    i got the navcore 9.026 & 845.2645 map installed but still didn't get the ASR .. i can see the icon but it's not letting me click on it.
    Also i can't do map correction update ...
    Thanks again
    steve uk's Avatar
    41
    Quote Originally Posted by TaNk View Post
    Thanks again
    Did you also download the se ttsystem file, that should enable the icon for ASR. Do you know what emulation your running i.e do you have a model.txt file in the root.
    Map share should work check your settings in tt home.
    In general you should get an update at least once a day. maybe not on sundays or bank holidays
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Should be applicable for you aswell http://gpsunderground.com/forum/show...=5606#post5606
    rgds jarkita
    Hi Steve,
    I got TT to get map share up ... i found a small fix inside these forums that enables update's etc .. i do have a patched ttsystem file but i don't see model.txt file.
    @ Jarkita
    I did put that file Support_ASR in my root of tt but still no ASR
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    @ Jarkita
    Not root -> folder asr in root
    rgds jarkita
    Yes .. i mean to say root/asr folder .. it told me there is already a filed called Support_asr and asked to over-wright and i did but still i can see the icon but unable to click on it ... ( hopefully we both are on right track .. I was asking about the Spoken Address (dialog ) thing )
    Thanks again
    TaNk
    Mod edit:
    ok now with navcore 9.026 & NAmerica 835-2419 map it still didn't work so i put my old backup back into TT & i got ASR back working....
    now does that mean G720 only works with 8351 & North_America_835_2419 map?
    i would realy love to update my navcore & map on Go720
    any idea guys?
    TaNk
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Did you try to leave (and patch) 8.351 and put 845 map?
    rgds jarkita
    Quote Originally Posted by jarkita View Post
    yes just tired that also but still same thing .. ASR won't work ..
