Thread: More TomTom Truck Help Please !
    romperstomper is offline Private
    I would like to know if i can install TT Truck on an SD Card to be used with my TT One V4,Ive been reading countless threads for the last few days and im still unsure ??
    If this is possible which Navcore and Map would i need for the UK? I tried to work it out using the Navcore Vs Maps thread but its got me baffled.
    I presume i would need a larger SD card as well.
    steve uk's Avatar
    steve uk is offline Sergeant
    41
    Re: More TomTom Truck Help Please !
    Navcore 8.395...map 840.2554 SDhc card 4gb as map is over 2gb need to know what your bootloader is to make sure sdhc cards will work. download a key generator to patch the map and navcore.
    Hi Steve, Thanks for your quick reply the bootloader is 5.30 if this is incorrect which one do i need?
    Thanks again !
    Thanks yuriyggg, One last thing is there a tutorial on how install/upgrade the bootloader??
