Thread: Navcore help.
    cacaiste is offline Corporal
    Colombia N.L.
    21
    Navcore help.
    After unloaded, how it look the navcore? it is the ttsystem or pna? This is my problem now, I don't know which file to change in the internal memory to change the navcore..
    Last edited by jarkita; 2nd June 2010 at 22:04. Reason: moved to apropriate forum, topic modified
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Navcore help.
    Quote Originally Posted by cacaiste View Post
    You should change all the navcore files ... Basically you can leave folders & its contens: art, helpme, licences, sounds, voices, zip and obviously mapfolder. Rest folders and loose files should be deleted and new navcore files/folders copied.
    rgds jarkita
