Thread: Problem updating TomTom
    Lightbulb Problem updating TomTom
    sorry I am not sure if I can post anything here! but I have tt ONE 3rd edition, nav core 8.01, lastest map 8.50, I ran as above, my tomtom can be operated and fully functional, however when loaded from tt device, "PROBLEM WITH MAP - MAP NOT VALID THIS THIS DEVICE, UK_IO.XXX.PNA". the ttsystems file not seems to be updated when "tt patcher", option 2 is ran.
    Please Help!!!
    Dutch Mountains
    285
    Re: Problem updating TomTom
    Quote Originally Posted by BATJAY View Post
    Please clarify. Is your problem with TTHome > operate my tomtom or is the Tomtom itself not running the map?
    Please use Easyusetools like following:
    1. Extract the Easyusetools folder and subfolders to the root of a hard disk in my pc (structure X:\easyusetools\ with subfolders)
    2. check that the meta.txt in subfolder \progs has a file meta.txt with the proper meta for your map.
    3. copy the files *.pna and *.meta from the map folder to the subfolder \insert_meta_from_Map_here
    4. write your 10 character device ID (from ttgo.bif) in a file called DeviceID.txt in easyusetools main folder. No spaces between the digits.
    5. run RunMeforDCT.cmd in a CMD dosbox. On Vista and Win7 go to Start > search box > type CMD and rightclick on the found cmd.exe then select "run as administrator".
    6. copy the resulting *.dct file into the map folder.
    Done.
    If you still have errors, post the output of the commands here, but anonymise your deviceID.
