Thread: cannot patch tomtom home help
    chaz is offline Corporal
    21
    cannot patch tomtom home keygen says correct dll missing for your device help please
    thanks in advance
    Dutch Mountains
    285
    Re: cannot patch tomtom home help
    You first need to have your tomtom download the dll file: When you connect your Tomtom to TTHome and select "Operate my Go" it will download the needed DLL file. Once you have it, you can patch it.
    Are you running a patched version of your original Navcore or are you running an SE version? In the last case, you also need to copy the data**.chk files from the root directory of your Tomtom to the directory on your PC where the DLL has been downloaded.
    there will this dll file be downloaded to??
    Dutch Mountains
    285
    XP: C:\Documents and Settings\????\ApplicationData\TomTom\HOME\Profiles \????.default\extensions\Navcore.7.?????@tomtom.co m
    Vista, 7: C:\Users\???????\AppData\Roaming\TomTom\HOME\Profi les\?????????.default\extensions\Navcore.8.?????@t omtom.com
