Thread: Help with map [Brazil][845.2697]
    I need help.
    Joined the two files using HJPLIT and put them in the maps folder in my tomotom Brazil.
    then put the zip file in the same folder.
    doing this, my tomtom has tilt, had to return to the old map.
    Can anyone help me?
    Dutch Mountains
    285
    Re: Help with map [Brazil][845.2697]
    On your tomtom there should not be a folder called maps. The combined file probably has some files inside a map called Brazil***. This map needs to be directly in the main tomtom folder.
    I don't know what zip file you have put in the same folder, but Tomtom does not read zip files.
