Results 1 to 7 of 7
Thread: Problem with meta
    Post Problem with meta
    Hi everybody;
    I would like to knwow how to get the meta code , i mean extract the code from an original version map whith original dct and get the meta like :
    " ; United_Kingdom_and_Republic_of_Ireland_850_YYYY
    XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX XX United_Kingdom_and_Republic_of_Ireland-000.meta"
    I've already try he cmd : "TT8_MAPCHECK.EXE DIRECTORY_WITH_ORIGINAL_FILE DEVICEID_OR_SERIALID P >>MC.TXT" something still going wrong to get the meta code of the map but I get the code of radar...ov2.
    so if someone can help me i'l keep on
    Dutch Mountains
    285
    Re: Problem with meta
    How get the blowfish code for a TomTom map?
    (Open "ttgo.bif" that is in the root of your device with notepad and get your serial and device-id)
    1) Download and UnPack EasyUseTools to C:\
    2) Copy the 3 files *.META, *.DCT en *.PNA from your
    country map to the folder .\insert_meta_from_Map_here
    3) Run RunMeforMetaKey.cmd - Choose option 1, then option 2
    4) The keygen will ask for your DeviceSerialNumber,
    not the 10 character device ID! ( K16167I00801 )
    This is also written on the bottom of your Tomtom.
    5) The keygen will ask for your DeviceUniqueID,
    the 10 character device ID! ( AA8AQQQYXX )
    All capitals, NO SPACE in between.
    It will give you the Meta on screen and in "Meta.txt".
    Hi heijx,
    Thanks for your quick answer.
    But in fact i just get this in the meta.txt
    ; Radar_FR_TomTom_2884
    23 70 04 97 96 B8 F1 8E C6 57 E8 52 D7 D5 63 92 Radar_FR_TomTom.ov2
    but any blowfish key for the map
    here is what i get in the mc.txt
    XXXXXXXXXX (my Device Id 10 digits)
    Patched firmware '8' mode
    Western_and_Central_Europe_2GB.pna - present
    Cline.dat - present
    Cname.dat - present
    Cnode.dat - present
    Mapinfo.dat - OK
    Internal Version = 730
    Flag = 1
    Bitflags = -------- -*---*** *****-*-
    Rect = (-1822566,2330000,6200000,7150000)
    Western_and_Central_Europe_2GB-169.meta - present
    Western_and_Central_Europe_2GB-169.meta.dct - present
    Western_and_Central_Europe_2GB.pna - OK
    Version = 850
    Build = 2820
    Map ID = 210637021
    cline.dat - Size OK
    Western_and_Central_Europe_2GB-169.meta - OK
    Wrong Serial Number length!
    Radar_FR_TomTom.ov2 - present
    Radar_FR_TomTomOv2.ver - present
    Radar_FR_TomTom.ov2 - OK
    {Pocket Device ID detected}
    Blowfish Key = 23 70 04 97 96 B8 F1 8E C6 57 E8 52 D7 D5 63 92
    dct/mct - OK
    And in mcseri.txt I've
    xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx (my serial device 32 digits)
    Cline.dat - present
    Cname.dat - present
    Cnode.dat - present
    Mapinfo.dat - OK
    Flag = 1
    Version = 850
    Build = 2820
    Map ID = 210637021
    cline.dat - Size OK
    Wrong DeviceID length
    wrong serial number length did i make a mistake somewhere ???!!! may be something different in map 850.2820 ???
    Thanks for your help..
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Quote Originally Posted by zebu974 View Post
    12 digits on barcode sticker C_NO ...
    rgds jarkita
    Sorry still going Wrong with 12 digits barcode here is the mcseri.txt
    HT04XXXXXXXX
    Cline.dat - present
    Cname.dat - present
    Cnode.dat - present
    Mapinfo.dat - OK
    Flag = 1
    Version = 850
    Build = 2820
    Map ID = 210637021
    cline.dat - Size OK
    Bad ID/Serial!
    First level , I thought that i could read the serial (32 digits) in the ttnavigator.bif in this case i read Wrong Serial Number length!
    For this reason 12 digits seem to be right but in this case i read Bad ID/Serial! maybe i'm wrong whith the barcode .
    It's an HTC HD2 an i read the barcode under the battery s/n : HT04XXXXXXXX
    so where is my mistake??!
    Dutch Mountains
    285
    HTC is not a Tomtom device so you cannot retrieve the meta with it.
    Hi heijx
    Did you mean that tt8_mapcheck is a reverse code grabber just for files issues from TOMtom Device and not files issues from Phone mobile device ?!!
    So I won't be able to share my map DAMMs!!!
    Thanks for all
