Thread: Map problem
    Thumbs up Map problem
    hi i tried Western_and_Central_Europe_850_2800 with tomtom go 550 live using alberts easy activator today it downloaded the meta and patched ok but when you select the map it just freezes on the select map screen, has somebody entered the incorrect meta to alberts database or am i using the wrong map version? according to tomtom uk web site 8.45 is the latest, other 8.50 maps work fine, and yes my tomtom is patched too. Thanks.
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Map problem
    No valid meta for this map available yet ... The one posted was fake.
    rgds jarkita
    Re: Map problem
    Hi, thanks i thought the meta was probably wrong, can someone advise the programmer for alberts easy activator so he can remove it from his master meta file. thanks.
    thanks jarkita for your help with this post.
    jarkita's Avatar
    Plymouth / Warszawa
    615
    52
    Re: Map problem
    Quote Originally Posted by pab2010 View Post
    Should be removed by now.
    Quote Originally Posted by yuriyggg View Post
    And this fake has a run on all forums ... and repeated again and again
    And cloned! There is not much we can do ...
    rgds jarkita
