Thread: Problem Hong Kong map
    Thanks Koos. However, I failed to install the map onto my TomTom Go.
    I used Albert's Easy Activator to generate the DCT file, then copied the map together with the DCT file to the device under the folder name "Hong_Kong". Unfortunately, the HK map didn't show up in the device.
    Have you successfully installed the map ? Can you tell if I am using the correct way to install the map? Thanks.
    jarkita's Avatar
    jarkita is offline Captain
    Plymouth / Warszawa
    615
    52
    Re: Problem Hong Kong map
    @Ithomas
    We need more details http://gpsunderground.com/forum/show...sking-for-help. Have you also patched navcore? What does tt say? Is map extracted correctly? http://gpsunderground.com/forum/show...ract-map-files
    rgds jarkita
