Results 1 to 8 of 8
Thread: uk safety camera incorrect speed on TomTom Nav 9.025 Map 845.2645
    fasgen is offline Private
    First time posting here, so sorry if anything wrong
    Problem is on my TomTom XL IQ with Navcore 9.025 and Western and Central europe 845.2645 map
    When i've installed uk premium speed camera database, everything seems to be ok apart of incorrect speed showing on screen, for instance in 40 mph zone my limit coming up as 25mph so it's like other way round set to kph. Have searched on the net and some people mentioned if that bug was even on tomtom oficial live service.Any ideas how to fix it or should i just use different cameras database or different navcore/map?
    Thanks in advance
    macapaca's Avatar
    Norfolk UK
    166
    Re: uk safety camera incorrect speed on TomTom Nav 9.025 Map 845.2645
    I use Speed Camera Data Base, you have to subscribe but its only 9.95 euros per year and its very easy to use and update.
    You simply copy 3 files into your map folder, set the POI active. Never had a problem.
    thanks for reply, but im still concerned about this if anybody knows how to fix this bug?
    xmassacrex's Avatar
    xmassacrex is offline Sergeant
    38
    can also try pocketgpsworld cameras which i use, just set the poi warnings for them:
    personally i prefer UK consolidated
    Quote Originally Posted by xmassacrex View Post
    That's all working fine, but i'm still would like to use premium uk speed cameras service, not POI type one.
    Tried to change language on russian,so it's reflect speed in kph, in that case 40 mph zone sign showing up correctly but my speed is in kph so still wrong Anybody else experienced the same problem?
    macapaca's Avatar
    Norfolk UK
    166
    Thousands before you had the same problem, but since this forum has been rebuilt with new admin, I can no longer point you to an answer
    thanks for all replies, didn't help much thought
    Finally got it working just with different navcore (8.410) if it helps somebody
    is anybody can drop me pm please how to fix it? need to use newer applications but with premium speed cam
    Anybody please!?
