Results 1 to 10 of 15
Thread: W&CE 2GB 850.2820 map problem
    Essex UK
    209
    Works great on HTC HD2 with meta
    ; Western_and_Central_Europe_2GB_850_2820
    CB 06 0E 1F 90 A7 CE 7E CD DD 06 DA 45 F5 A9 85 Western_and_Central_Europe_2GB-169.meta
    Just one question, iv never noticed before but when I connect to TomTom Home and click add map, it shows the map as 850.2820.2820 an says no information available.
    Is this normal.
    Re: Western_and_Central_Europe_2GB_850_2820
    Works great on my HTC TyTN Navigator7.....Thanks!!
    Luis is offline Sergeant
    Portugal
    49
    39
    Hi
    Doesn't work on my HTC Touch2 with TomTom Navigator 7.918. I've tried activating for 2 times and nothing, TT don't see the map. This happens with more people?
    Best regards and my thanks to uploaders.
    edited: I've tried the same map on my Mio P550 with TT 7.917 and with the same activation method works fine... I'm crazy with this!!!
    KIT-KAT is offline Lance Corporal
    Quote Originally Posted by Luis View Post
    Hi
    It works perfect on my HTC Diamond with Tomtom Navigator 7.918. I“ve activated only 1 time and Tomtom see and do the work with the map correctly.
    Check the meta or try to change the program for generate .meta (i suggest you easy activator)
    Best Regards.
    Portugal
    49
    39
    Hi KIT-KAT
    Thanks for your reply, I'll try with another activator even when it works fine for my Mio P550 with the same map. Only TT is 7.917 and WM5.
    Best regards
    mikejt2000 is offline Lance Corporal
    Good question, one that i would like to ask. any answers
    Is this normal.[/QUOTE]
    Good question any replys
    When i go to show the map version in my TT 7.918 it says "Western_and_Central_Europe_2GB_850_2820" and version v850.2820.
    Tuziukas is offline Corporal
    21
    Quote Originally Posted by KIT-KAT View Post
    not believe..
    Essex UK
    209
    Ok thats fine so does mine using 7.915 (9196), that wasnt the question though.
    Im talking about when you connect to TOMTOM HOME and click add maps it says 850.2820.2820 no imformation available.
    It seems at some point an extra 2820 has been added to the map ID.
    I check the version map iin tom tom application and is says the same:
    The size: 1482 Mb.
    The Version: 850.2820
    I“m using a HTC Diamond (PDA). Maybe in PNAs the versions appears different.
    I hope you believe me (again)
    Best Regards.
