Results 1 to 7 of 7
Thread: Problem with Iberia map
    Hmm anyone help me with this one.
    TomTom Go 530
    Ver 8.351(9982/090518) OS:315187
    GPSv1.20 Boot 5.5120
    I have 2 bought maps on my SD card but am going away to Spain on Friday so wanted to grab the Iberia map to use for the week.
    I downloaded EasyUseTools and watched the video tutorials on how to use it.
    I downloaded the map and extracted it to a folder called Iberia. (21 files 276MB - Is that correct?!)
    I copied the map to the SD card and copied Meta.txt into the root of EasyUseTools applications.
    Meta.txt therefore just reads.
    ; Iberia_850_2781
    B1 84 C7 C3 8B 2F EF 76 C2 DF 7A EF C8 18 32 50 Iberia-161.meta
    *I assume this is OK that I don't have my bought maps as they are already working fine?!
    When I run RunMeforAllAutomatic it detects my device its ID and I press ENTER to go on.
    I select option 1) To run the Keygen and I get the following:
    ### Run Fake meta.txt Check ###
    !!! There is no key for United_Kingdom_and_Republic_of_Ireland-132.meta in 'Meta
    .txt'
    !!! There is no key for Iberia-161.meta in 'Meta.txt'
    ## Map not in meta.txt ##
    ### Run Keygen ###
    E:\United_Kingdom_and_Republic_of_Ireland\United_K ingdom_and_Republic_of_Irelan
    d-132.meta.dct exist already
    E:\Iberia\Iberia-161.meta Map not activated
    Used DeviceID from ttgo.bif = XXXXXXXX (I have removed this myself!)
    Used tt8_keygen2.exe
    Press any key to continue . . .
    As you can see it's not activating my map.
    I then copied the .meta and .pna files over to the insert_meta_from_Map_here folder in case that was the issue but that didn't help either.
    Any ideas?!
    Re: [Iberia][850.2781]
    Have also tried Alberts Easy Activator with no luck (
    tsinuski is offline Corporal
    16
    "I copied the map to the SD card and copied Meta.txt into the root of EasyUseTools applications."
    I use 'Easyusetools for Keygen Mapcheck Metacheck ttsystempatcher'
    Meta.txt should go to the Progs folder.
    Cheers m8
    Quote Originally Posted by tsinuski View Post
    Cheers m8
    Tried that and now I get:
    .txt'
    Iberia-161.meta v850 bld2781 Key is FAKE
    ## Mapkey in meta.txt is a FAKE ##
    ### Run Keygen ###
    Used DeviceID from ttgo.bif = XXXXXXXXXX
    16
    This is what I usually and always do:-
    (Do this on the PC)
    (We are using "Easyusetools for Keygen Mapcheck Metacheck ttsystempatcher"). And assuming you have your device id in DeviceID.txt)
    Copy the two map files (country_name.pns & country_name.meta) to folder 'insert_meta_from_Map_here'
    Put a copy of meta.txt (either a single line relevant meta data or a full list of all available data) to folder 'Progs'
    Then run 'RunMeforDCT.cmd'
    Select option 1, (ENTER) and again option 1 (ENTER)
    Your country_name.meta.dct will be created.
    Just copy this to the map folder where you found the .pna & .meta
    Now copy this map (folder) to the sd card.
    There you go.
    Hope this works for you.
    Cheers
    I have iberia 850.2781 running in my g0630
    You are a life saver! Did that and bingo!
    Many thanks!
    16
    You're welcome.
    Glad I'm of use to somebody!
