Thread: Help! Please....
    mirage is offline Corporal
    18
    23
    Help! Please....
    Well, I'm trying to run TomTom on a 2DIN autoradio but when I start tomtom navigator it doesn't find the map.
    I tried with a MAP directory in the SD root; I tried with a MAP directory in the Navigator directory; I even tried with a Iberia-map directory in the SD root but the message is always the same "No Map found".
    Can anyone tell me where do I put the map files?
    Thx
    PS: the map files had been patch (unlocked) already.
    Dutch Mountains
    285
    Re: Help! Please....
    Is the navigator itself patched too?
    Normally, a country map is not placed in any "map" superdirectory, but directly into the root of the SD card, like in your case Iberia.
    18
    23
    Thx Heijx.
    The navigator and maps are patched but right now the map, which is in the SD root, is recognized by the navigator but I don't seem to get a fix in the GPS.
    The gps unit is detected but some how it keeps braking the connection with the system.
    It isn't a problem in the unit because it works perfectly with iGo, NDrive, Polnat but with TomTom... I'm going to give it another try with a different Navigator version to see what happens.
    Does anyone know a stable Navigator version to run in a 2DIN chinese autoradio?
    I'm using a TomTom_WinCE "ApplicationVersion=7910"
