Thread: go520 iq routes and lane images problem
    hello
    yesterday my new sd card arrived, i copied over all the files from the internal memory except the map.
    the internal memory has app 8.351 and uk & roi v715.1703.
    on the sd card i have patched the app 8.351 and installed two maps these are france v850.2820 and uk & roi v850.2820.
    These are working fine along with tomtom speed cameras.
    What i'm having problems with is the lane images and iq routes. On the device when booted from the sd card the 'hide lane images' icon has a red cross through it.
    When I tap on the icon tomtom pops up a message that the map version is not compatible with lane guidance.
    Also I cannot find any reference on the device regarding iq routes. Any idea what be could be causing these problems?
    Many thanks
    Least
    doshow's Avatar
    doshow is offline Corporal
    Re: go520 iq routes and lane images problem
    Hello least,
    850.2820 does not support ALG/Advanced Lane Guidence nor do I find that it has IQ routing. You need to look on the Map chart and locate a Map that supports ALG, and has IQ like 850.2781 - 850.2794 - 850.2800
    Quote Originally Posted by doshow View Post
    Hello least,
    well that would explain it!
    I was under the impression that all 850.#### maps supported it, I did find the charts slightly confusing though. Thanks for your help, I'll grab 850.2800 and give it a go.
    EDIT: just checked the chart again and its all clear, previously I didn't notice the left hand columns. Cheers
    tsinuski is offline Corporal
    16
    You'd be better off with 850.2781 maps.
    No meta available with 850.2800, yet.
    yep i've put 2781 on. thanks!
