Results 1 to 7 of 7
Thread: I'm in nomans land need help?!?!..
    Liveforever is offline Private
    Unhappy I'm in nomans land need help?!?!..
    Hi everyone,
    I'm totally new to this GPS stuff, I spend 2 week searching for infos after getting a TomTom one as a gift,
    problem is it came with full AUS map and i need to put my little country in it,
    somehow got a Garmin nuvi with unlocked mapsource map of our counrty, is there any way i can use it in my TT.
    i borrowed the original .img map file and mapsource .gdb file and also the converted garmin gmapsupp file.
    will thiese help, please please help.
    Megalos's Avatar
    Megalos is offline First Sergeant
    Holland
    149
    Re: I'm in nomans land need help?!?!..
    No, it's not possible to use Garmin maps on a TT. I would recommend you choose one here: You need to patch the NavCore (the operating system of TT) before you can use this 'free' maps. As you're a beginner, read these wonderful tutorials:
    hi forgot add, I'm having a TT GO730 (4CH7.000.02) how does this tell whether i'm having a updated on or not.
    also this came with an empty SDCard (dummy) so i replaced it with one of my used but newly formated 64mb card with some photos.
    seem its not connecting or identifing the card - any idea guys??
    gmhr is offline Private
    64mb is no were near big enough get a 2gb load on a good navcore like 9026_one then choose a map.
    Megalos's Avatar
    Holland
    149
    Is there a NavCore on the internal memory of the TT? Photo's should be in the 'photos' folder on the SD-card or internal memory.
    Hi Megalos, i'm not how far i understood your question, but yes my TT is working with a AUS map and yes there are 6 photos in the Photos folder, with odd numbering like - Slide05 , 10, 22, 38, 46 & Splashw - does these says anything??
    Hi all, I'm still waiting for an answer. please help
    Help Help Help!!!!!
    i have one more simple question - if i provide the Map datas is it possible for me to get a TomTom version for TT.
    Please do give a responce..Thanks in Advance.
