Thread: Problems (?) with SE Navcore 9.101.516023.2 [Go 630]
    abandonow is offline Private
    Question Problems (?) with SE Navcore 9.101.516023.2 [Go 630]
    Hi all! I recently bought a Go 630, since it was reasonably cheap and should be pretty good to mess around with.
    Ive tried SE Navcore 9.101.516023.2 with the newest maps and it loads up fine. The problem accured when I tried to set a route from Bjerregaards gate, Oslo, Norway to Lingonstigen, Domsjö, Sweden. I get a route that is around 200 km longer than google maps comes up with.
    When I boot up the original navcore and map (8.45) I get a route simular to google maps. I also got someone else to test with the newest map, and he also got a simular route to google maps.
    Is it the Navcore that is the problem? If yes, could someone recommend me a good one for the Go 630 (I would like to have the anti aliased map feature of later navcores)
    Thank you!
    (and Ive read the FAQ etc. They are great btw. )
    gmhr is offline Private
    Re: Problems (?) with SE Navcore 9.101.516023.2 [Go 630]
    Hi
    Not sure if this will help but its worth a try, use Navcore 9026_one as I have it on a Go 300 and its faultless.
    Good Luck
    Thanks. Figured out that it was the map version that did the difference.
    The map versions chart that comapres maps with Navcores is what sorted all my issues out.
