Thread: Using PDA with TomTom Home
    u2_storm is offline Private
    Hopefully a quick question as I cannot find any files do it so far.
    I would like to be able to connect up my current pda to TomTom home and allow it to do map sharing etc. What version of Tomtom home would I need and what files do I need to drop onto the root of my device?
    Thanks for your help!
    Essex UK
    209
    Re: Using PDA with TomTom Home
    if tomtom is installed to the device memory you only need to install tomtom home and connect via active sync, if tomtom is installed to your memory card then you will need some form of crack, which unfortunately i dont have.
