Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Need your help for western europe Tomtom One 7.166
    wacly is offline Corporal
    24
    Unhappy Need your help for western europe Tomtom One 7.166
    Hello
    I am new in this forum and I find it very great and helpful. But I have a serious problem : I remove without attention the file western_europe_1Gb from my tomtom ONE 3rd edition 7.166.
    Today I'm searching it because it's very importante : This GPS is not mine !
    Can you help me please ?
    Thank you for your attention.
    Hazzing's Avatar
    Hazzing is offline Sergeant First Class
    Denmark
    114
    Re: Need your help for western europe Tomtom One 7.166
    Quote Originally Posted by wacly View Post
    Hello
    Maybe the owner has taken a backup of the internal memory, before leaving it up to you to do your thing. The original map you have deleted is way old, so try to look for backup or delete all of the internal memory and
    use a patched navcore and all new map.
    Navcore Map Tutorial
    24
    ok thanks for your great reponse !
    So you advise me the tutorial
    EDIT : I read the tutorial and I find it quite difficult. I don't understand how can I patch my navcore and which newest version compatible with my map can I choose. If you help me that will be very great !
    gmhr is offline Private
    You need to use the run all tool and patch as on screen ,keygen,tt system etc.Make sure navcore compatiable with map.Lists are in the map section at top.
    24
    I don't know how to choose compatible map with my navcore
    Excuse me but I am a newbie. I have never change maps before !
    Hazzing's Avatar
    Denmark
    114
    The map I have recommended is ok for your need and I've found a navcore that is compatible with the map.
    Navcore
    You will also need a tool to activate your map and this is what I use
    Map Activator
    Download map and Alberts Activator and of course the navcore.
    You will have to read the tutorial because whatever I write to help is what you will find in the tutorial.
    But I can give you the short version..........
    Delete all content on the TT.....copy the navcore from your PC to the TT (root).....copy the folder, containing the map, to the root of the TT.
    Start the map activator and follow the steps through the map activation......and you're good to go.
    But remember.....this was the short version.....I hope I've remembered everything......c",)
    If not, then I'm sure one of the Admins is going to give you/me a hand in getting you back on track........
    24
    ok thanks for your help, I'm going to try it
    I am waiting for a confirmation from an admin
    EDIT : what map can I choose please ?
    Hazzing's Avatar
    Denmark
    114
    Whatever map you want......845 or 850....you decide! Europe 850.2800 would be a good choice
    24
    ok thank you
    Can you help me about the install of Navcore please
    yeah I know I am a big newbie !
    Edit : 850.2800 is for Europe, I want a map for western Europe please because I have just 1 GB without slot MicroSD
    Hazzing's Avatar
    Denmark
    114
    ok thank you
    Just do as told earlier. Delete the content of the TT and copy the unzipped navcore files onto the TT(root).
    Then use the 845.2666 map of western Europe. It's for 1Gb TT's.
