Results 1 to 10 of 14
Thread: problem tomtom one map Not found
    hacker88 is offline Private
    hi ,
    I wanted to install a map Tomtom Southern Europe V850.2820 in tomtom one version 7.903
    message : The map is Not found
    Know you why
    I am to sadden for my bad English
    THX
    Dutch Mountains
    285
    Re: problem tomtom one map Not found
    Is the map properly copied to the Tomtom?
    It should reside on the same memory as the navcore since a Tomtom One cannot read SD card when internal memory is active and cannot read internal memory when SD card is active.
    Also it should be in a one-level folder:
    x:\Southern Europe\Southern Europe\***files*** is incorrect.
    x:\Southern Europe\***files*** is correct.
    Also you need to patch the map but also the navcore.
    hi ,
    My tomtom has no internal memory, (It) works with a card sd , Without card sd my tomtom does not work
    The map I have him (it) patch With tomtom activator
    my map It finds x:\Southern Europe\files
    Dutch Mountains
    285
    Try patching with Easyusetools, as I never have problems with that application.
    Patch the navcore and the map.
    Thank you for quite your answers ,
    On this forum there is a tuto to explain the use of Easyusetools
    macapaca's Avatar
    Norfolk UK
    166
    Quote Originally Posted by hacker88 View Post
    Open Notepad and type in your device number xxxxx xxxxx but with NO space between numbers
    Click save and save as "DeviceID.txt"
    Save to the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder (overwrite
    existing file if asked)
    Open the "Prog" folder inside the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder
    Open the "meta.txt" file with notepad and check to see if the meta txt for your downloaded new map is there, if not, add it in the same format as the rest, and "save"
    Open the map folder you downloaded
    Copy the files (map_name.pna) & (map_name.meta)
    Open the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder
    Open the insert_meta_from_map_here folder (should be empty)
    Paste the files (map_name.pna) & (map_name.meta) into it
    Run the "RunMeforDCT.cmd" file In the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder
    When asked, type "1" ENTER, and when asked again type "1" ENTER
    Read Confirmation in lower section (Keygen says OK) if all went successfully press any key to continue
    Open the insert_meta_from_map_here folder (should now be 3 files in it)
    Copy the (map_name.dct) file
    Paste it into the map folder you took the (map_name.pna) & (map_name.meta) from
    thx For your explanations , He work not
    Further information : my map france , benelux Which be on my gps , have The extention .pna and .mms and .mid
    There is not of extention .dct and meta
    It is necessary can be patch all systeme ?
    If yes How it is necessary to make
    hi ,
    I found my problem , My gps sets that .mms maps And do not support .meta
    1 : A patch exists you he to put maps meta
    or
    2 : i search map europe.mms
    THX
    Dutch Mountains
    285
    A DCT file you create with the patching tools, but a .meta file and a .pna file should be there otherwise the map is not complete.
    Try to download a map from a different location.
    hi ,
    Thank you for quite your answers , Everything works
    The problem be maps which I had to download
    You have a very good forum
