Thread: Voice and then sound cuts out
    katana is offline Sergeant
    30
    20
    I have a TT One with patched everything working fine
    However, when I chose some voices, the sound totally cuts out and I am unable to turn the TT off.
    The only cure is to swap the voice to one I know works and then reset the device - the old paper clip in the hole trick.
    The voice in qustion are the new premium KITT voice - UK Yards (succesfully craked) and an old Dalek voice.
    There are probably others, but these anoyed me the most.
    Yes I know it's not a life threatening condition, but I would be nice to know why it happens.
    Hopefully a quick question, I have searched the other threads and found simliar faults, but not exactly the same!?!?!?!?
    bigfella is offline Sergeant
    32
    Re: Voice and then sound cuts out
    yup mine did this ..... i had to patch tt system as well as voices .. i used alberts easy activator .. button on the left at the bottom to do this
    30
    20
    Quote Originally Posted by bigfella View Post
    Thanks for the reply bigfella.
    My TT system is already patched to accept maps etc. Do you mean I need to do this everytime I put on a new voice??
    32
    no shud only need it once,,, try patchin voices in a map on ur desktop n then copyin n pastin to voices in root of tt
