Thread: This is my Newbie Guide from the original GPS Underground Forum
    macapaca's Avatar
    Norfolk UK
    166
    THIS IS MY ORIGINAL GUIDE FROM 18 MONTHS AGO, WHICH WENT DOWN WITH THE OLD FORUM ... Macapaca
    NEWBIES GUIDE TO UPDATING TO SE NAVCORES WITH MATCHING MAPS:
    MAPS ARE UPDATED 4 TIMES PER YEAR, THE CURRENT MAP NUMBER BEING A HIGHER NUMBER THAN THE PREVIOUS
    FIRST CHECK THE CHART FOR MAP VS NAVCORE COMPATABILITY IN THE FORUMS MAPS SECTION
    PC REQUIREMENTS:
    Microsoft NET Framework v2.0 or higher needs be installed to anable the patching of the "ttsystem" file.
    Download it from Microsoft.com
    DOWNLOADS:
    Make a new folder, call it "8.XXX + 850.XXXX" or what ever your new downloaded
    navcore and map numbers are going to be, (makes life easier, fewer mistakes).
    Download - The latest version of KEYGEN (presently 4.1D) or another activator (Easytools)?.
    Download - The SE Navcore of your choice, and UNZIP it in the new folder
    Download - The Map of your choice, and UNZIP it in new the folder with the navcore
    IMPORTANT - Make a note of the "meta txt" for the map your are downloading
    MAKE NOTEs:
    Connect to a PC
    Start your TOMTOM
    Open to your root
    Open "ttgo.bif" with notepad
    Write down your App (Navcore) number (EXAMPLE: 8.351.9982)
    Write down your Map number (EXAMPLE: United_Kingdom_and_Republic_of_Ireland_830_2305)
    Write down your device number (EXAMPLE: AK47Z CJHGT)
    Write down your bootloader version number (EXAMPLE:5.5120)
    BACK UP - IF YOUR TOMTOM HAS NO CARD SLOT:
    First open "Folder Options" in the control panel of your PC
    Click the "View" tab
    Select "Show hidden files & folders" (MOST IMPORTANT)
    Click "Apply" followed by "OK"
    Back up all the files in your TOMTOM using "Windows Explorer" to a folder of
    your choice, so as not to get confused call it "Old working backup" or whatever
    Turn off your TOMTOM and disconnect from PC
    Shut down "TOMTOM HOME" (right click the TT symbol in the right of the PC taskbar
    select "Exit")
    BACK UP - IF YOUR TOMTOM RUNS FROM AN CARD CARD:
    Exactly as above to back up to a PC
    Or get a new card, (class 4 or 6 write speed, higher the better)
    Format cards 2Gb or less as FAT, cards over 2Gb FAT32
    Swap the cards over for safety before you continue and keep your old one as the backup
    COPYING NEW FILES & FOLDERS TO DEVICE OR CARD:
    Now that you have backed up, delete all content from your device or card.
    Open the new folder you named "8.XXX + 850.XXXX"
    Copy the entire contents to your device or card
    PATCHING THE NAVCORE:
    SE NAVCORES ARE ALREADY PATCHED AND READY TO GO:
    HOW TO PATCH THE MAP:
    WITH KEYGEN:
    Connect your tomtom to the PC
    Shut down TT Home
    Start the keygen (Run as Administrator in Win 7)
    Click on Downloads / meta, to update the meta txt, click back when done.
    Click on the icon make map keys, overwite original DCT's, Make DCT's
    When done shut down Keygen
    Shut down tomtom and disconnect from PC
    Boot up Tomtom, should now work OK
    WITH EASYTOOLS:
    Open Notepad and from your notes, type in your device number xxxxx xxxxx but with NO space between numbers
    Click save and save as "DeviceID.txt"
    Save to the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder (overwrite
    existing file if asked)
    Open the "Prog" folder inside the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder
    Open the "meta.txt" file with notepad and check to see if the meta txt you previously
    noted down for the new map is there, if not, add it in the same format as the rest, and "save"
    Open the map folder you downloaded
    Copy the files (map_name.pna) & (map_name.meta)
    Open the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder
    Open the insert_meta_from_map_here folder (should be empty)
    Paste the files (map_name.pna) & (map_name.meta) into it
    Run the "RunMeforDCT.cmd" file In the Easyusetools_for_keygen_Mapcheck_ttsystempatcher folder
    When asked, type "1" ENTER, and when asked again type "1" ENTER
    Read Confirmation in lower section (Keygen says OK) if all went successfully press any key to continue
    Open the insert_meta_from_map_here folder (should now be 3 files in it)
    Copy the (map_name.dct) file
    Paste it into the map folder you took the (map_name.pna) & (map_name.meta) from
    It should now work OK
    ..........MACAPACA.
  2. The Following User Says Thank You to macapaca For This Useful Post:
    Re: This is my Newbie Guide from the original GPS Underground Forum
    thanks, i am getting stuck at no meta.txt found when i try to run runmefordct.cmd in easy tools. I am trying to load a middle east map onto tt one xl. i have follwoed instructions and added the .meta for middle east to the text. What can i do? thanks in advance
