Results 1 to 7 of 7
Thread: 520 with 8.396 & Latest Truck Map 845.2649 Problem
    akacheesy is offline Corporal
    27
    Keep getting the same error message "Problem with this map, you cannot use this map on this device:Europe_Truck-134"
    Can anyone help please?
    Oh & also have a meta-error txt file in notepad which reads "!!! There is no key for Europe_TRUCK-134.meta in 'Meta.txt'"
    27
    Re: 520 with 8.396 & Latest Truck Map 845.2649 Problem
    thanks for your reply but its a bit too cryptic?
    27
    sorted it m8, thanks again
    Quote Originally Posted by akacheesy View Post
    Hi
    I'm getting the following message:" Problem with map. You cannot use this map on this device: Europe_TRUCK-132"
    Could ypu please explain how you solved your problem??
    27
    I gave up & used the older map which works just fine
    Good morning.
    I found the "step by step" Guide on this Forum and managed to get it working.
    Thank you guys
    Regards
    Einar
    colabot is offline Private
    Quote Originally Posted by einarmel View Post
    Good morning.
    Thank you guys
    Regards
    Einar
    Hi Einar,
    For the benefit of myself and others having the same issues, can you please explain where you found the guide and which map you had success with.
    Thanks.
    Cola
    EDIT: No need, have sorted it.
    For the benefit of others reading this thread, get the latest version of Easy Use Tools.
    This is copied from elsewhere but is what I used.
    The latest Easytools will generate the truck meta. If you cant find it download this which contains the latest Easytools and tells you how to do it:
    Or
